LabWindows/CVI
MultiFileselectPopup locks up when called
I have found that on a computer with a network, and a network disk which is connected but broken (you know, the small red cross under the drive character in the Windows explorer), the Multifileselectpopup function hangs when it is being called. The hour glass appears and before the popup window appears the program locks up, until the disk becomes available again.
I'm not sure this it a CVI issue, because Windows is searching for a disk it can't find, but it would be graceful if after something like 10 seconds the search was abandoned. What exactly is happening here, and how can it be avoided?
Erwin Timmerman
Message 1 of 1
(2,897 Views)
