LabWindows/CVI
Multiline ToolTip
I can generate a single line ToolTip, but am having no success producing a multiline ToolTip.  Any suggestions?
(4,366 Views)
you should use the attribute browser for this case, see the figure below, it provides a 'ring popup' tool...
(4,363 Views)
Accepted by topic author jrbecker
Hi jrbecker,
In LabWindows/CVI 2012, you can create multiline tooltips in one of the following ways:
  • Insert a newline character (\n) in the string of the ATTR_TOOLTIP_TEXT attribute.
  • Insert a newline character (\n) in the string of the Tooltip Text field in the Attribute Browser.
  • Click the arrow in the Tooltip Text field of the Attribute Browser and select Edit multiline tooltip text.
https://www.ni.com/docs/en-US/bundle/labwindows-cvi/page/cvi/uiref/tooltipsoverview.htm
If there's an update we can make to the documentation that can help make this task easier, please let me know!
April
Technical Writer
LabWindows/CVI
(4,347 Views)
Using CVI 9.0, so no Attribute Browser.  But the \n worked great.  Thanks.
(4,339 Views)
