LabWindows/CVI
Multimeter configuration - Driver and ethernet connection
Hi everybody !
I am currently using a multimeter (Keysight 34461A) with an ethernet connection for my project. I downloaded the driver of the instrument but I did not managed to make my system work..
In the function main, I entered the following lines:
ag3446x_InitWithOption("TCPIP::192.168.0.120::5024::SOCKET", VI_FALSE, VI_FALSE,"Simulate=0, RangeCheck=1, QueryInstrStatus=0,Cache=1", &handle_session);
ag3446x_ConfigureMeasurement(handle_session, AG3446X_VAL_FREQ, AG3446X_VAL_AUTO_RANGE_ON, 1E-6);
ag3466x_ConfigureTrigger(handle_session, AG3466X_VAL_IMMEDIATE,0.0);
ag3446x_Read(handle_session, 5000, &freq);
However, I am not sure of the declaration of the TCPIP connection, in the Initialization step, 192.168.0.120 is my IP adress, 5024 is my remote port.
I only found tutorials for GPIB connection, has someone already configured a multimeter with a driver and an Ethernet connection ?
Thank you in advance for your help !
(3,385 Views)
Hello emilie_grd,
I suggest you to first verify if your multimeter is well connected to your network and then to check if MAX detects it.
Following link will give you a clear guideline:
http://www.ni.com/getting-started/set-up-hardware/instrument-control/ethernet-connect
Also, have you installed this driver?
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E1C5CF089F15079AE0440021287E65...
Have a nice day,
Armando
(3,353 Views)
