LabWindows/CVI
Multiple YAxis Chart with LW/CVI
Is it possible to release in Labwindows a Stripchart with 3 or 4 YAxis??? I'd like to plot 3 or 4 charts with different scales.
Thank you for your help!
Alex
Message 1 of 9
(5,367 Views)
You can use CWgraph ( an ActiveX from Component Works ) that allow you to use different axis ( one per plot for example ). You can set the position, the colour, the style, the value ( discrete, ...) Very nice product.
Message 2 of 9
(5,366 Views)
I have never used ActiveX. How can I integred an CWgraph in my "uir" or program. Do you know where can I find a sample???
Thank you!
Alex
Message 3 of 9
(5,366 Views)
I found CW3dGraph.fp but I can't find CWgraph.
Please give me some help or some details about CWgraph.
Thanks!
Alex
Message 4 of 9
(5,366 Views)
Did you have Components Works ?.
In this case, create a uir and add a control "ActiveX" nammed CWGraph. Double clic on it and you can see a button "Property Sheets" that allows you to create plots, axis,....( of course it's possible programmatically").So, you can configure your control. After that you have to use it by programm. Right click on the graph and select "Generate ActiveXdriver".
Message 5 of 9
(5,366 Views)
Thank you very much. I get it!!!
Have a nice day!
Alex
Message 6 of 9
(5,367 Views)
Yes you can. I've just tried it but it seems to works fine.
Message 7 of 9
(5,366 Views)
Can you send us an example of the code that you develops?
Message 8 of 9
(5,082 Views)
Here is a uir file that has just the CWGraph component with two Y axis labels.
Adam
Message 9 of 9
(5,034 Views)
