LabWindows/CVI
Multiple instance of an executable
I'll try to be as clear as possible.
I'm writing  a program that emulates a DDE server and I want to be able to run multiple instances of that program.
At the beginning of the program, I ask the user to input the name of the DDE Server to emulate and I want to see in the task manager my instances of program with different names, ideally the name given to the DDE Server.
Has anyone an idea ?
Thanks in advance.
Franck.
(3,852 Views)
Hello Franck.
Here is a possible solution:
  1. Download and install the free Sysinternals Suite from Microsoft
  2. Run the included Process Explorer utility procexp.exe
  3. In Process Explorer, select View / Select Columns, and check the Window Title box
  4. In your application, after the user has entered the server name, call SetSystemAttribute (ATTR_TASKBAR_BUTTON_TEXT, ddeServerName);
  5. The entered name should appear in the Process Explorer Window Title column
Good luck.
Colin.
(3,830 Views)
Hello Colin,
It does what I want.
Thank you for your help.
Franck.
(3,808 Views)
