LabWindows/CVI
Multithreading Issue
Application:  2 Threads
Thread 1 does something
Thread 2 does something but if a certain condition is met, locks thread, writes to excel, closes excel file, opens a new excel file, releases thread.
Issue:
   After Thread2 is locked and after the following command is excecuted
   ExcelRpt_WorkbookSave
   Thread1 for some reason releases and continues to run
Does anyone know why this command is releasing threads ?
Diego
(6,128 Views)
How are you locking the threads? Could you post some sample code?
JR
(6,103 Views)
JR,
This is the basic version of it. Highlighted bold command is the one that causes Thread1 to continue running.
Everything works fine if I remove the Excel commands out of the Lock section.
Main
  //excel
  ExcelRpt_ApplicationNew (VFALSE, &applicationHandle);
  ExcelRpt_WorkbookNew (applicationHandle,&workbookHandle);
  ExcelRpt_GetWorksheetFromIndex (workbookHandle, 1, &worksheetHandle);
  ExcelRpt_ActivateWorksheet(worksheetHandle);
  //multithreading
  runThread = TRUE;
  CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE,Thread1, &Beagle_thread, &Beagle_thread);
  CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE,Thread2, &Host_thread, &Host_thread);
  CmtNewLock (NULL, 0, &mylock);
Thread2
  Do something
  if(blah blah)
    CmtGetLock(mylock);
    //update tables
   ExcelRpt_WorkbookSave (workbookHandle, Datalog_Dir,ExRConst_DefaultFileFormat);
   if (worksheetHandle) CA_DiscardObjHandle(worksheetHandle);
   if (workbookHandle)
      ExcelRpt_WorkbookClose(workbookHandle, 0);
      CA_DiscardObjHandle(workbookHandle);
    if (applicationHandle)
       ExcelRpt_ApplicationQuit(applicationHandle);
       CA_DiscardObjHandle(applicationHandle);
     CmtReleaseLock(mylock);
(6,090 Views)
Just to make sure: are you trying to get the lock in thread1 too? If not, thread1 is not effectively locked and you only seem to have it blocked under normal condition; on special conditions, since report saving and activex stuff are relatively long lasting operations you can notice that thread1 is still running.
(6,085 Views)
Roberto,
Sorry for the confusion.
I want to lock thread1( as in pause it) when blah blah condition is met in thread2, I then want to execute all the functions in the if statement ( while thread 1 is locked).
And then finally unlock/release thread1 when all the functions in the if statement in thread2 are completed.
Diego
(6,078 Views)
As Roberto says, you need to use CmtGetLock(mylock) in your Thread1 code as well. Since you did not show any code for Thread1, we cannot assess what the problem might be.
JR
(6,074 Views)
additionally, i would strongly recommend creating the lock BEFORE creating the threads with CmtScheduleThreadPoolFunction().
as it is written now, the threads start while the lock still does not exists, with a risk to badly fail on lock acquisition...
(6,062 Views)
