LabWindows/CVI
Multithreading advantages
Could you name advantages of multithreading refering to applications
written in CVI ?
[We assume that the apps are designed for single processor system]
________________
thanks in advice
Frog
(3,192 Views)
There is a document that ships with CVI 5.5 or greater that you can refer to. You can find it under \cvi\bin\MultithreadingOverview.pdf. There is a section called "Reasons for Multithreading" that answers your question. If you are using 5.0.1 or previous, those versions do not include multithreading libraries and debugging capabilities.
Best Regards,
Chris Matthews
(3,192 Views)
