LabWindows/CVI
Multithreading: doesn´t update UIR
From my main panel (UIR) and through this functions:
CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE, Myfunction, (void *) &DataMyfunction, &threadID);
CmtWaitForThreadPoolFunctionCompletion(DEFAULT_THREAD_POOL_HANDLE, threadID,OPT_TP_PROCESS_EVENTS_WHILE_WAITING);
I display a new panel
Myfunction
DisplayPanel2()
ProcessSystemEvents()
ProcessDrawEvents()
Another_function()
DisplayPanel3()
Another_function
Update Value controls and color label controls (for the 2nd panel)
The problem is that the control value update its value always I change It with SetCtrVal
But the label color doesn´t change its value always I change it with SetCtrlAtribute (, ATTR_LABEL_COLOR, ))
It only changes when I Display a 3th panel.
I think ProccesSystemEvents() should solve this problem
Any Ideas?
Message Edited by norak on 03-24-2010 10:54 AM
Message Edited by norak on 03-24-2010 10:55 AM
Message Edited by norak on 03-24-2010 10:56 AM
(3,715 Views)
Accepted by topic author norak
SetCtrlAtribute() does not redraw.  Would you not want to call ProcessDrawEvents() after the call to AnotherFunction()
(3,677 Views)
ok,
Calling ProcessDrawEvents() after a SetCtrlAttribute(), the UIR updates.
I need do so, because the UIR need to update after each change, not after all changes...
Thanks a lot for your replay
(3,655 Views)
