LabWindows/CVI
My CVI program can not operate PCI-DIO-96
I distributed a CVI 6.0 program and one installation can not operate the digital I/O. The other installations work fine. Win2000, NI-DAQ 6.9.3, CVI SQL toolkit installed. NI-DAQ error 1605 came up during one of the NI-DAQ install cycles.
(2,991 Views)
Hello:
Please refer to the following KnowledgeBase:
http://digital.ni.com/public.nsf/websearch/BB8084BBFDFF0E4986256C0800700CD0?OpenDocument
As you will see, Error 1605 during the install process is a disk-space error. Do you have enough disk space to install NI-DAQ? If so, try copying NI-DAQ 6.9.3 to your hard drive and running the installer from there. (You can also download NI-DAQ 6.9.3 from http://www.ni.com/downloads/).
Good Luck!
Sincerely,
Brooks B
(2,991 Views)
