LabWindows/CVI
My USB-6501 will run test panels fine but not supplied examples in CVI
When I run any of the examples I get a "NON-FATAL RUN-TIME ERROR", creating a DI or DO channel results in the Status Code -201003. The device cannot be accessed. I have LabWindows/CVI 8.0 and DAQmx 8.5. Any hints would be appreciated, thanks.
(3,686 Views)
DaqMx examples are all hard-coded in that device configuration is included inside the source code and can possibly be different from your actual configuration. For example, ReadDigChan sample project reads from Dev1/port0/line0:7 (taken from UIR control): check you actual board configuration and adapt sample code according to it.
(3,682 Views)
Thanks, got it working. I wrongly assumed that when NI say that example is for a particular board, it will work for that particular board.
(3,669 Views)
Hi Kazino,
Is there a particular example that you were having difficulty with?  I would like to take a look at the documentation and address any concerns that you have.
Jennifer O.
(3,644 Views)
