LabWindows/CVI
My html help file is not being displayed.
I am using the function, "ShowHtmlHelp (HelpFilePathname, HH_DISPLAY_TOPIC, NULL);".  HelpFilePathname contains the path to my help file, called TLL-Help.chm.  If I click on the chm file directly, the help file opens with no problems.  But from within my code, it doesn't open, and I don't get any errors.
(3,071 Views)
did you check the return value of the function ?
(e.g. Status = ShowHtmlHelp (HelpFilePathname, HH_DISPLAY_TOPIC, NULL); )
or, maybe, the help components server is not installed ?
see function help:
This function requires that the HTML Help components server, specifically hhctrl.ocx, is present on your system.
Once the game is over, the king and the pawn go back into the same box.
(3,054 Views)
