LabWindows/CVI
My project is freezing after building.
I'm working on a project for a while now, and it was functionig perfectly well. Now, when i'm trying to debug my program, it's builded, but then CVI is freezing, and the program isn't launching.
The .exe file is nevertheless created, and i can use it to test my program, but i can't do a debug session.
Other projects are launching perfeclty well. I also tried it on other computers, and the result was the same.
Does someone has a clue for my problem?
Thank you in advence!
P.S. I'm using CVI 2013
(3,654 Views)
Ok, I found where the problem come from, it is the same as this one http://forums.ni.com/t5/LabWindows-CVI/labwindows-2013-not-responding/td-p/2972213
Thank you!
(3,648 Views)
