LabWindows/CVI
N9320B functions missing in ivi driver
I'm using the N9320B spectrum analyser and the ivi driver found on the ni website to measure the channel power of a desired frequency
To do that i'm doing the following actions
1)       agn9320ni_ConfigureMeasurementType (parameters are :  MeasurementType 2)
2)       agn9320ni_ConfigureAverage ( parameters are : AverageEnabled 1 ; AverageCount 5 ; AverageMode 1)
3)       agn9320ni_ConfigureFrequencyCenterSpan (parameters are : CenterFrequency xxHz ; Span 2.0MHz)
4)       agn9320ni_ConfigureCHP (parameters are : IntegrationBandwith 200KHz ; ChannelPowerSpan : 400KHz )
5)       agn9320ni_ConfigureSweepCoupling (parameters are : resolutionBWauto 0 ; resolutionBW 3000Hz ; VideoBWauto 0 ; VideoBW 3000Hz ; SweepTimeAuto 1 ; SweepTime 0.1002s )
6)       agn9320ni_ConfigureLevel (parameters are : amplitudeUnits ; inputImpedance 0 ; referenceLevel 0 ; ReferenceLevelOffset 0 ; AttenuationAuto 1 ; Attenuation 0 )
7)       agn9320ni_ReadMeasurementCHP (parameters are : MaxTime_ms ; MainchannelPower = output ; powerdensity = output )
Now I have some issues with step 2 not being applied and step 4 not changing the channelpower to 400KHz
(2,855 Views)
Regarding this is a duplicate post, it might be best to handle this in the following thread:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/N9320B-ivi-functions-not-working-properly-ave...
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,843 Views)
