LabWindows/CVI
NDIS access from CVI application using Rawether SDK
Has anyone used the Rawether Win32 NDIS "C" API to access NDIS from a CVI application?
The API, a product of PCAUSA,  provides access to raw 802.3 (Ethernet) frames (packets), so that you can implement your own protocol without creating any device drivers.      http://www.rawether.net/
Menchar
(3,796 Views)
I always use Rawether as a packet filter sdk,it's funny
(3,745 Views)
I realise that this is a really old thread BUT - with PCAUSA no longer in existence due to Thomas Divine sadly passing, I don't suppose you have a copy of the Rawether SDK code? It doesn't seem possible to obtain any longer.
(1,520 Views)
What sort of Windows version do you hope to use?
There used to be WinPCap that allowed similar functionality but it was eventually stopped and its NDIS based device driver had problems in Windows 8 and higher. In place of it there is now NPcap which has a device driver that supports the new NDIS 6  from Windows 7 and higher and is in that respect fairly future compatible.
Rolf Kalbermatter  My Blog
(1,487 Views)
