LabWindows/CVI
.NET 4.0 - Function CDotNetInvokeGenericMember return with -6571
Calling .NET assambly throws an exception in Function "CDotNetInvokeGenericMember". I invoked the beamgage automation interface, which properly work with Labview 2012, but not with Labwindows/CVI. Initializing assembly and creating target was OK.
(3,987 Views)
Hi raama,
which version of CVI do you use?
in which version of LabVIEW did the assembly call work?
Did you try this sample code?
Sample Code for Calling .NET Assemblies: http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvidotnet_sample_code/
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(3,955 Views)
Accepted by topic author raama
I found the solution by myself. The reason was, some Dll's called by the assembly DLL where not found. I registered only the assembly DLL. The folder of Labview Example was below the assembly folder.
(3,943 Views)
