LabWindows/CVI
.NET Controller tool
I'am trying to reuse some code , which was written by a collegue in managed VC++. Did I understand right, that I can do that by building a .Net Assembly and creating an interface for CVI to it with the .Net Controler tool?  As I don't know VC++ very good: Are there things, I have to do  on the VC++ side to be compatible with the .Net Controler tool ? My first try only shows "Error occured while generating .Net controler Code. Fehler in der Anwendung". Any´hints to documentation for that are welcome.
(3,319 Views)
If I try to reformulate your request, you would like to integrate some Visual C++ code into CVI. Did I get you right?
I selected some useful links for you:
How to Integrate 32-Bit Microsoft Visual C/C++ or Borland C/C++ DLLs into LabWindows/CVI 4.0
http://www.ni.com/white-paper/3453/en
Does LabWindows/CVI Support C++?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6EPSA0&l=en-US
Could you tell me more about the error you got? Have you received any error codes ?
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
(3,255 Views)
