LabWindows/CVI
NHR 4600 AC LOAD
Is anybody out there who controlled the NHR4600 AC Load using LabWindows 6.0/7.0? I need newer .dll,.h and .lib files and sample CVI codes? Any help?
Regards
(4,478 Views)
The NHR 4600 product page, says that there are LabVIEW drivers available for your instrument. However, it appears that I must be a customer of NHR to log into the support section of the web site, and I have not been able to find these drivers on other NHR web pages.
If you are able to obtain the LabVIEW drivers for this device, then it will be possible to use LabVIEW to build the .dll .h and .lib files necessary to use the driver in LabWindows/CVI.
Scott Y
NI
(4,451 Views)
