LabWindows/CVI
NI-6535 in continues mode.
I wrote this code in order to output a train bits continuously.The code is:
#include <NIDAQmx.h>
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "test_6535.h"
#include "toolbox.h"
// Constants
// Types
// Static global variables
static int panelHandle;
// Static functions
// Global variables
// Global functions
#define NUM_SAMPLES  100
/// HIFN The main entry-point function.
int main (int argc, char *argv[])
float64 adDutyCycle[1], adFreq[1];
int32 iSampleWritten;
uInt8 abArray[NUM_SAMPLES];
TaskHandle gTaskHandle;
int error = 0, i = 0;
unsigned __int64 ui64Samples = NUM_SAMPLES;
 for (i = 0; i < sizeof (abArray); i++)
  if (i % 2)
   abArray[i] = 0;
  else
   abArray[i] = 1;
 adDutyCycle[0] = 10.;
 adFreq[0] = 1920;
 DAQmxCreateTask ("",&gTaskHandle);
 error = DAQmxCreateDOChan (gTaskHandle, "6535/port0/line3", "",
          DAQmx_Val_ChanPerLine);
 error = DAQmxSetTimingAttribute (gTaskHandle,
          DAQmx_SampQuant_SampMode,
          DAQmx_Val_ContSamps);
 error = DAQmxSetTimingAttribute (gTaskHandle, DAQmx_SampClk_Rate,
          2500.);
          DAQmx_SampQuant_SampPerChan, ui64Samples);
 error = DAQmxWriteDigitalLines (gTaskHandle, sizeof (abArray), 1,
         10.0, DAQmx_Val_GroupByChannel,
         abArray, &iSampleWritten, 0);
 while (1)
  ProcessSystemEvents ();
    return 0;
The program executes DAQmxWriteDigitalLines only once and than stops transmitting.
My question is:
What I need to do in order to transmit the data  continuously?
Best regards
Etai.
(2,876 Views)
Are you working from an example program or is this some code you wrote? The function help for ProcessSystemEvents suggests a piece of code (below) to run continuously.
while (!done)
RunAdditionalStep ();
Also, there are some continuous digital examples in the DAQmx folder that should have been installed with the software. Start Menu » National Instruments » NI-DAQ » Text Based Code Support » ANSI C
Jake H | Product Manager
(2,861 Views)
