LabWindows/CVI
NI 8517 Flex Ray
Dear answers
I plan to use a 8517(two ports) card to test two ECU at the same time. One port connect to one ECU.
But when I use the Xnet driver in the CVI do the debug and find only connect the two ports to one ECU at the same time, it can successfully communicate.
In that case means I need to two 8517 (two ports) to test two ECU.
Is there any body tell me is it mandatory to connect two ports to one ECU at the same time when we do test? What is the real reason?
Message 1 of 1
(1,337 Views)
