LabWindows/CVI
NI-CAN API example
Is a example codes LabWindow/CVI anywhere for NI-CAN?
(4,447 Views)
Accepted by topic author Deeyu
Hi Deeyu,
Yes, there are several NI-CAN examples that can be found by using the Example Finder in LabWindows/CVI.  From the main splash screen, click Find Examples, then do a search for CAN.
These can also be found by going to C:\Users\Public\Documents\National Instruments\CVI\Samples\nican
You need to make sure that you have both LabWindows/CVI and the NI-CAN driver installed for these to show up.  When installing the NI-CAN driver, make sure you select the option for LabWindows/ CVI support and examples.
Austin S.
Academic Field Engineer
(4,439 Views)
Hi,Austin
I didn't find nican folder in this samples folder:
~\National Instruments\CVI\Samples\
And I didn't see CAN in NI Example Finder, (see picture)
Is there something wrong?
Thanks.
(4,298 Views)
Yundong,
Do you have the NI-CAN driver installed?  If I'm not mistaken, these should show up in the noted folder locations.
Also make sure that you have the LabWindows options selected in the install that I mentioned above.
Austin S.
(4,282 Views)
