‎10-23-2003 06:41 AM
‎10-24-2003 11:30 AM
‎10-24-2003 03:06 PM
‎01-11-2010 09:54 AM
LuisG wrote:
Yes, the speed improvements are tied to the version of NI-DAQ, not the ADE. Therefore, you will receive the same benefits in CVI. Keep in mind however, that in order to be able to use NI-DAQ 7 in CVI, you need to upgrade to CVI 7.
Luis Gomes
NI
CVI6.0 will work with NIDaq7..see NIDAQ7 readme
The following table lists the application software versions supported by NI-DAQmx and Traditional NI-DAQ.
| NI Application Software | Versions Supported by NI-DAQmx | Versions Supported by Traditional NI-DAQ |
| LabVIEW | 7.0 | 6.0—7.0 |
| LabVIEW RT module | — | 6.0—7.01 |
| LabWindows/CVI | 7.0 | 6.0—7.0 |
‎01-11-2010 11:29 AM
I should have been clearer in previous post. When I wrote NI-DAQ 7, I was really referring to NI-DAQmx, not Traditional DAQ.
Luis
