LabWindows/CVI
NI DAQ mX migration in CVI
I have serious problems to migrate from traditional to mX NI-DAQ drivers using LabWindows CVI. Unfortunately NI presses much more on LabView than on CVI, and I found only tutorials dealing with LabView (maybe I am wrong !).
Nevertheless, please find attached a piece of code which you will define "old style programming", but that actually is the only one I am able to deal with 🙂
I would so much appreciate if some of you experts around can translate that code using NI-DAQ mX functions rather than Traditional primitives. This will be of real help for me to begin walking inside this new driver.
Thanks in advance,
Marco Sartore
(3,386 Views)
Your program is doing a simple period measurement. You can essentially replace your program with four DAQmx function calls:
DAQmxCreateTask
DAQmxCreateCIPeriodChan
DAQmxReadCounterScalarF64
DAQmxClearTask
The first two DAQmx functions take the place of your first six GPCTR functions. Then, you just call DAQmxReadCounterScalarF64 once (not in a loop) and it will block until your reading is available (this replaces your two GPCTR_Watch calls). Then call DAQmxClearTask to clear the task.
I'm sure you'll find that counter operations are so much easier with DAQmx. Good luck to you.
Joe
(3,365 Views)
Here are a couple of other suggestions: make use of the DAQ Assistant + Code generation, as well as the DAQmx C example programs, when getting up to speed with DAQmx.
Joe
(3,359 Views)
Many thanks for your help !
The Joe's step-by-step translation of my code was really helpful to me.
Let me try to go one step further: merely translating my code was a great thing and will work but does not generate optimized code, I mean not so optimized as DAQmx allow to do. Is it true ?
In fact, I believe that DAQmx allow to acquire multiple sample (i.e. multiple counter scalars) without the need of a formal acquisition loop (my "old" for). In this case I suppose that I can leave an acquisition task running freely, while another task only plots the acquired data. Should I use DAQmxReadCounterF64 function ? Where should I put my plotting instructions, maybe in an asynchronous timer callback routine, polling a data array and plotting the last fresh acquired samples ?
Many thanks again and best wishes,
Marco
(3,326 Views)
