LabWindows/CVI
NI-DAQmx 9.2.3
Need example code in Labwindows/CVI (NI-DAQmx 9.2.3). for scxi-1121 with scxi-1321 shunt cal
(2,925 Views)
Greetings Mongo,
Unfortunately, it seems there is no existing example that meets all your criteria.  If you are in need of code that will meet exact criteria, I can suggest you visit our Alliance Partner website.  https://www.ni.com/en/partners.html
There are examples/documentation available, just none that meet all your needs.
SCXI-1321 Terminal Block Calibration Procedure
https://www.ni.com/docs/en-US/bundle/370254a/resource/370254a.pdf
Hope this helps.
Best Regards,
Michael G
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
(2,864 Views)
