LabWindows/CVI
NI MAX (measurement & automation explorer) not installed with NI-DAQmx version 17.0
I use LabWindows/CVI on a Windows 7 machine and recently installed NI-DAQmx version 17.0.  Now I can't find NI MAX installed anywhere on my computer.  The webpage: https://www.ni.com/en/support/documentation/compatibility/16/measurement---automation-explorer--max-... clearly states at the top that NI MAX is included with the NI-DAQmx installer.  Yet after I ran the NIDAQ1700f0Runtime.exe installer twice and rebooted each time there was no NI MAX anywhere.  Then I came across webpage: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9tuSAC which states,  "The NI System Configuration package only contains MAX, the System Configuration API, and the NI Network Browser. It is the closest to a direct download for MAX.  But after installing syscfg1700runtime.exe I still can't find NI MAX anywhere on my computer.  Please reply with any thoughts or ideas you might have.
(5,810 Views)
Hi skinnedknuckles,
Have you tried opening it from?
C:\Program Files (x86)\National Instruments\MAX
Try this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PA8LSAW
If you don't find that folder. Try installing System configuration again using this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8U0SAK
If neither work, I think the fasted way is uninstalling all NI software and reinstall from scratch. Reimagining the computer might be faster actually.
PedroR
(5,762 Views)
Accepted by topic author skinnedknuckles
You are running "runtime" installers. I do not think runtime installers will install the MAX.
You need a full DAQmx install. This is the link:
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
S. Eren BALCI
IMESTEK
(5,752 Views)
Hey ebalci,
You were correct.  I tried installing NIDAQ1700f0.zip instead of NIDAQ1700f0Runtime.exe and now I have MAX.  I don't quite know the difference between the two files but the former one installed MAX as I needed.
Jonathan
(5,743 Views)
Runtime installers include necessary components for running the developed programs.
MAX is more like a development tool. Probably, you can run a DAQ progam on a computer without having NI MAX.
That's why it is not a part of the "runtime" installer. The link I provided is for installing the full development environment, with many components for many development tools (LV, LW, VB, C/C++, .NET, etc).
S. Eren BALCI
IMESTEK
(5,730 Views)
