LabWindows/CVI
NI PCI 8431 Use DMA instead of Interrupts?
I have two PCI 8431 cards installed in my PC (A8N-SLI Motherboard) running Windows XP.  I am recieving data on 16 out of the 18 channels at a rate of ~500K bits per second.  I keep getting a Hardware Overrun error if I collect data for a extended amount of time.  I noticed that the 8431 cards are setup to run on IRQs.  National advertises these card to run using DMA.  How do I make these cards use DMA channels instead of interrupts.
Message 1 of 1
(3,224 Views)
