LabWindows/CVI
NI Report trouble shooting
I use NI report as the result output solution, but I do not know how to control the page output , e.g., how to compute the total pages , how to print the specified page numbers . Due to each table has the fixed column name , I hope that on each output page , it can keep the column name contents at the table head , how to realize this function ? your advise is highly appreciated . Thanks .
David
(2,852 Views)
David,
I couldn't find much in the way of that specific functionality in the NI Reports documentation. You may want to check out an example that I have attached for some ideas. It seems that in order to accomplish these tasks you may need to use Excel through Active X.
You can find out some more information about NI Reports by following this link.
You may also want to check out the help index in CVI. In CVI go to Help->Contents and type 'Reports' in the search box under the Index tab. There you will find some additional examples and documentation. If this information fails to help you out then please post back with more details.
Good luck!
Craig H.
(2,852 Views)
