LabWindows/CVI
NI-Report
Hi all,
I programmed my application with CVI 6.0. Using NIReport I want to print a mulicolumn table in A4-format (portrait). If the sum of all columns is greater than 16 cm, the table is printed with a witdth of about 16 cm. Some of the columns are reduced in width. Which one seem to be undefined.
Printing normal text, header or footer lines shows that the behaviour of programmed margins (left, right, upper, lower) works for this elements, but not for multicolumn tables. They begin not at the left margin.
I tried with several printers (HP-Laser-Jet 6MP, HP-Colorlaserjet-4500C, HP-Deskjet 970C and DEC-Laser 3500) in PCL or Postscript-Mode. The result is always the same.
Any suggestions for creating multicolumn-tables with a width greater than 16 cm?
Willi
Message 1 of 1
(3,096 Views)
