04-27-2010 06:32 AM
Hi
Can I use a recent NI USB-6501 - 24-line Digital I/O (NI-DAQ) with LabWindows/CVI 7.0, even if Labwindows/CVI 8.x is required ?
Thank you
Dayn
Solved! Go to Solution.
04-28-2010 02:41 AM
Hello.
In DAQmx Readme, you can see which version of CVI are supported by the actuel DAQmx version. For a 6501 card, 8.7.2 or 8.9.5 DAQmx versions will work.
Regards
