LabWindows/CVI
NI-USB-8451
I am having a problem with NI USB 8451. I am using Labwindows 7.1 to compile, and it compiles fine, but when I try to run the application, an error messages pops up, saying that it require a Labiew Run-time Engine, version 8.2 (or equivalent). I am not entirely sure what I need to do. I am using a dll that interfaces with your Labview driver for that particular device.
(3,273 Views)
You can download the LabVIEW 8.2 Run-Time Engine for free.
Mert A.
(3,267 Views)
With NI-845x Driver version 1.1, you can use the NI-USB-8451 with text based programming, including CVI.
Chris R.
(3,185 Views)
