LabWindows/CVI
NI Xnet CVI
Dears
Is anyone know what do this command use for?
I see this in configure the NxCan Send configuration in CVI.
Termination = nxCANTerm_On
Do that mean the the 8513 card will provide a 120R terminal resistor during the can communication?
(2,207 Views)
Accepted by topic author JasonZha
If it will provide a termination resistor would depend on the actual hardware. Not all hardware supports software controllable termination.
According to this your 8513  card provides software controllable termination when the port is used in high speed mode.
Rolf Kalbermatter  My Blog
(2,111 Views)
Thank you, Rolfk. Yes, I get it when I measure with a multimeter.
(2,100 Views)
