LabWindows/CVI
NI update service failing
Hi!
I am trying to update my labview install and am getting errors trying to do so.. Anyone know what I can do?
Please find attached the log file that was generated.
Ton
(3,427 Views)
Hi tikihiki
First I recommend you to disable the firewall and antivirus and if you are still having problems then you might install the latest version of the NI update service.
Which version of LabVIEW do you have?
Regards
Esteban R.
(3,407 Views)
HI Esteban,
Thank you for your reply.
I tried updating the update service, but it told me I was using a newer version. I ended up removing all installed components and am in the midst of reinstalling everything now.
I am using LabView 2012.
Will let you know how the new install works out for me.
(3,395 Views)
Hi tonverra
Your welcome, let me know if you still have any problem after reisntalling everything.
Regards
Esteban R
(3,386 Views)
