LabWindows/CVI
NI6251 buffered digital output/clock
Actually I'm having few issues with the attempt to generate a SPI similar pattern. So I need to generate a clock with the proper pin(using a pin of port0). For some reason I'm having trouble select and to use the right external Source to generate the clock. Do you have any Suggestions to solve the problem? Docs, example 🙂
Thanks.
(4,444 Views)
re-posted in the LabVIEW forum here
(4,380 Views)
