LabWindows/CVI
NIReports TableSetColWidth
Anyone knows
why if i create a table with 5 cols and set 5 col at 12 with
TableSetColWidth i can fill cells in right mode and if i set 5 col at 13 or
14 first row has this look ???
| col 1 | col 2 | col 3 | col 4 | col 5
| <--- why this space ????
I use cvi 8.0 on xp sp2
Thank's
Marco
(3,292 Views)
Dear Marco
Can you try to post an example that reproduces the issue you described. I can try to open it in different versions of CVI to verify the behavior.
Thank you
Hudson
(3,275 Views)
