LabWindows/CVI
NON-FATAL RUN-TIME ERROR: error return value==-58
Hello All,
Please help, every time I rebuild my project I got an error and sometimes not. The highlighted with red color is the error.
int CVICALLBACK Timer1CB (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_TIMER_TICK:
   GetCurrentDateTime (&now);
   FormatDateTimeString (now, "%H:%M:%S  %p  %d  %B  %Y", TimeBuffer, 100);
   SetCtrlVal(panel,au_STRING, TimeBuffer);
   break;
 return 0;
NON-FATAL RUN-TIME ERROR:   "Cobot_Machine Interface.c", line 217, col 13, thread id 7768:   Function SetCtrlVal: (return value == -58 [0xffffffc6]). The control does not have a value.
Thanks in advanced!.
(4,617 Views)
Accepted by topic author Master_Viper
I solved the problem now.
(4,601 Views)
Hey Master_Viper,
Could you post your solution so that other users can get help with this issue in the future?
Cheers,
Ryan C.
(4,595 Views)
There is conflict on two uir with the same name. So, what I did is delete the other file.
Master_Viper
(4,586 Views)
