LabWindows/CVI
NON-FATAL RUN-TIME ERROR: "t:\...\CVI2012\instr\hpe363xa\Hpe363xa.c", line 108, col 28, thread id 0x00001160: Function viOpen: (return value == -1073807202 [0xbfff009e]). Une bibliothèque de code ne peut pas être localisée ou chargée.
Bonjour,
Je suis débutant sur LabWindows/CVI 2012, version d'évaluation.
J'ai ajouté un "Instrument driver", le hpe363xa.h pour commander un E3631A de Agilent (Alimentation +6V, +25V, -25V).
Je souhaiterais juste tester et compiler la fontion suivante:
hpe363xa_init ("GPIB::5", VI_ON, VI_ON, &E3631A_Handle);
Après compilation, je n'ai pas de problème.
Mais dès que je fais un RUN de mon simple programme, pendant l'éxécutinon du programme j'ai l'erreur suivant:
Comment faire pour éviter cet erreur durant l'éxécution du programme.
Merci pour vos réponses.
(3,539 Views)
Hi skanpaul,
Sorry for the English. This is a common error that typically indicates an issue with the installation of NI-VISA on your system. Below is a link to a KB that describes a few possible solutions. Note that the KB error message is a LabVIEW error dialog, but the error and issue is the same for CVI.
"Error -1073807202 : A code library required by VISA could not be located" When Using NI-VISA
(3,529 Views)
I just can add that in case you want there is a French page of the forum.
(3,524 Views)
Thanks for you reply and there is no worry for the discussion in English.
I succeed to solve the problem in an another way.
I forgot to say that I used an GPIB-USB interface from Agilent, the 82357B, NOT one from NI.
Solution: (as beginner)
I opened MAX and went on: Tools menu --> NI-VISA --> VISA Options
and I did the following (see attached picture)
After that I runned my program with the desired/wished function and I succeed to control my instrument.
Sorry but I can't explain exactly what fixed the problem inbetween or in background.
Thanks anyway
(3,512 Views)
