LabWindows/CVI
NULL pointer argument to library function
I am testing my PCIe-6321 board with LabWindows CVI 2012 and DAQmx. A very simple test code as in the attachment was written and compiled okay. But when I ran, I got the following error message:
FATAL RUN-TIME ERROR: "DAQmxCodesTest.c", line 34, col 9, thread id 0x000025A8: Null pointer argument to library function.
Line 34 is as follows:
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,nSamples,10.0,DAQmx_Val_GroupByChannel,gData,nSamples*NumChannels,&numRead,NULL));
When I ran the DAQmx AnalogInput  example codes, there was no errors generated and ran properly with proper voltage output. [By the way for many DAQmx calls with NI boards, the default is in DIFFERENTIAL mode when using the DAQmxCreateAIVoltageChan(). It took me a while to figure out after digging through the CVI HELP calls. I hope this info may help someone later.]  But for this particular call, can someone help me what was wrong with it?
(9,066 Views)
You must allocate memory on gdata array before passing it to DAQmxReadAnalogF64
(9,062 Views)
Accepted by topic author bopja
(9,045 Views)
