LabWindows/CVI
NaN constant CVI 8.0
I realize this topic has been explored before, but I can't seem to get to the archived messages (2004)
Is there a way to use the IEEE NaN as a constant?  I have a struct of doubles I'd like to initialize to NaN, and I need a constant to do so.
I tried the ivi.h IVI_NAN as an initializer but the compiler barfs and says it's not a constant.
C99 apparently has such a constant in math.h, but the C89 CVI compiler doesn't  😞
When is NI going to give us a C99 compiler for CVI?
Hayes
(4,735 Views)
NaN can be found in
Programmer's Toolbox -> NotANumber()
or see toolslib\toolbox\toolbox.c
There are compare funtions like IsNotANumber(), too.
/* Nothing past this point should fail if the code is working as intended */
(4,730 Views)
That doesn't do the trick - has to be a constant.  NotANumber() is a function.
C99 allows non-constant initializers for structs and arrays, but the C89 CVI compiler requires constants.
When is NI going to give us a C99 compiler for CVI?   It's not too much to ask, given the cost of CVI.  I keep running into issues that are a problem with C89 but have been fixed in C99.
Hayes
(4,710 Views)
Hi Hayes,
I understand your frustration.  We have had a number of customer requests for a C99 compiler and I know that R&D is looking at this.  A great way to get your voice heard is to submit a product suggestion at our product suggestion center (http://digital.ni.com/applications/psc.nsf/default?openform).  All of these suggestions to right to R&D.
As for your question about NaN, have you seen this post:  http://forums.ni.com/ni/board/message?board.id=180&message.id=8449&requireLogin=False?  Perhaps the last suggestion would work for you.
Thanks for the feedback,
Megan B.
(4,695 Views)
Megan -
Thanks for the reply.
No, as I stated in my first post, the IVI NaN "constant" isn't really a constant - apparently it's a macro dereferencing a pointer to a NaN value somewhere in the IVI library.- the C89 CVI compiler flags it as an error ("must be a constant").  The dereferencing is a run-time activity that can't be handled at compile time.
I'll send my suggestion to the link you provided.
Hayes
(4,691 Views)
