LabWindows/CVI
Need Help on LabWindow/CVI
Hello all,
      I am new user of LabWindow/CVI. i need some help in getting through this software. is there any beginners guide or Manual to learn about programming on LabWindow/CVI.
(3,867 Views)
Ahoi,
there should be an Acrobat Reader document called "gettingstarted.pdf" in CVI's bin directory (C:\Program Files\National Instruments\CVI81\bin). This file contains a little tutorial where you learn how to build a user interface, generate code etc... The files needed for this tutorial are located in the "tutorial" directory (C:\Program Files\National Instruments\CVI81\tutorial).
If you're still stuck, let us know...
(3,863 Views)
You may also want to consider signing up for the LabWindows/CVI Basic I and II courses. Check out the Training and Certification section for more information.
Best Regards,
Jonathan N.
(3,850 Views)
Best Regards,
Okay, that was the response of an NI guy Smiley Wink
(3,847 Views)
