LabWindows/CVI
Need NI-FGEN 1.5.1. Web site link is incorrect (points to 2.2.1). Please advise.
Where can I find NI-FGEN Ver. 1.5.1? The web site link actually points you to Ver. 2.2.1, which will not work since I am using CVI Ver. 5.5.
(3,324 Views)
Try using this link. I went to the Drivers and Updates section, choose all versions and selected Signal Sources.
Bilal Durrani
NI
Bilal Durrani
NI
(3,324 Views)
The link you mention actually points to Ver. 2.2.1. Click on the link then run the .zip that is downloaded. It will be Ver. 2.2.1. I can find the link on the the websitem however, it is wrong.
(3,324 Views)
When i tested the link, it took me to a page with all the currect versions and 1.5 was in the list.
Bilal
Bilal Durrani
NI
(3,324 Views)
Sorry, I didnt understand the initial problem. If you check out the readme, it mentions that it does support using CVI 5.5. The fp for fgen 2.x should work with CVI 5.5 as well. There were no breaking function panel changes between the different versions of CVI and since you are using the fp and the import libraries, you should not have any problems.
I'll inform the appropriate people to make the document a bit more clear.
Bilal
Bilal Durrani
NI
(3,324 Views)
