LabWindows/CVI
Need help changing the picture of a command button during a run
Hey,
I'm trying to make a command button change its image during EVENT_LEFT_CLICK
and change back to original at EVENT_LEFT_CLICK_UP
is there a way of doing so?
(2,470 Views)
You can use
a) SetCtrlAttribute with the ATTR_IMAGE_FILE attribute or SetCtrlBitmap
b) a picture toggle button and call SetCtrlVal on EVENT_LEFT_CLICK_UP to make it spring back.
See Programming with Picture Button Controls.
/* Nothing past this point should fail if the code is working as intended */
(2,414 Views)
