LabWindows/CVI
Need help in easytab.fp
I am trying to release my application, originally my app is written in 32 bit using labwindows cvi 2008, now I have migrated it to labwindows cvi 2015 version, First I started with releasing using configuration>> Release option, with no issue and then later i change it to Configuration>> Release64 and I get issues related to Easy Tab Control. Also, I read few post based on easytab from the forum and got to know I should add Easy Tab Control in library, which i have added, but issue still continues. Please suggest some solution that I can try.
Attaching a pic of my errors.
RShah
(2,891 Views)
Accepted by topic author riddhi_shah
The EasyTab control is deprecated as it has been superseded by native tab controls; furthermore, it is not supported in 64-bit release, and since it is deprecated it is not likely to be updated anymore.
If you want to remain in 64-bit environment the only solution you have is to move to the UI tab controls.
(2,856 Views)
Thanks Robberto, that helped, I replaced all Easy Tab controls with UI Tab controls and seem to work.Smiley Happy
Riddhi
(2,739 Views)
