LabWindows/CVI
Need help on passing reference VARIANT or void * type
I would like to retrieve unknown type array from my function, I did read about VARIANT help (and Any Array type in page 2-7 of LabWindows/CVI Instrument Driver Developers Guide) ... but could not do any thing about this matter. Here how I would like to have:
I call a function with passing a reference variable (might be a VARIANT type, or void *?), I expect there is an array wiil be retunned as reference, that array will contain char*, int, double, short ... values that I do not know in-advance
How I create this function? And can I use library library ActiveX, Variant Related functions to retrieve their proper types?
Many thanks for any help or guidances
(4,955 Views)
I can see two ways to develop your function:
  1. Use void * type adding a field that describes data type passed
  2. Use a variant relying on this datatype intrinsic ability to show associated data type
In the first case you can take as an example ConvertArrayType function in AdvancedAnalisys Library, whose definition is as follows:
void            CVIFUNC ConvertArrayType(const void *sourceArray, int sourceDataType, void *targetArray,
                                        int targetDataType, int numberOfPoints);
As you can see, a void pointer is passed to the function together with a data type field that describes which type is passed array. The function can then properly handle the array passed to it.
In the second case, CA_VariantGetType () function can be used to retrieve the data type associated to the variant and correctly retrieve data in a properly allocated array. A sample on using this function can be found in DataTypesServer and DataTypesClient samples located in <cvidir>\samples\activex\servers\DataTypes folder.
(4,951 Views)
Hi Roberto,
I tried the 2nd option & it worked, however I need a bit more help on the retrive information: Here my codes:
#include <cviauto.h>
void GetVariantValues (VARIANT *var_ptr)
       unsigned int  i_val = 12;
       double db_val = 34.56;
       char *str = "ABC";
      CA_VariantSetInt (var_ptr, i_val);
      var_ptr++;
      CA_VariantSetDouble (var_ptr, db_val);
       var_ptr++;
       CA_VariantSetCString (var_ptr, "ABC");
int main (int argc, char *argv[])
       VARIANT     var_ptr[3];
       int i_type;
       if (InitCVIRTE (0, argv, 0) == 0)
       return -1;    /* out of memory */
       // Just for clarify the CAVT type numbers
       i_type =  CAVT_UINT;      // = 103
       i_type =  CAVT_DOUBLE;   // = 105
       i_type =  CAVT_CSTRING;   // = 115
       GetVariantValues (var_ptr);                                // var_ptr returns with 3 different types successfully
       i_type = CA_VariantGetType (var_ptr);              // first value return is  i_type  = 103   (CAVT_UINT)
       var_ptr++;                                                           // **********   If add this line ---> ERROR COMPILE  *****************
 return 0;
I saw var_ptr return with all values I need to recieve but I can not retrieve the 2nd & 3rd values ... can you help here? I tried to increase the pointer or use var_ptr[1] or var_ptr[2] ---> compile error!
Many thanks
(4,924 Views)
Hi again,
I did find the way to increase the pointer as the following:
 i_type = CA_VariantGetType (var_ptr+1);
 i_type = CA_VariantGetType (var_ptr+2);
And it works, thanks for help Smiley Happy
(4,918 Views)
Yes, it's equivalent to the notation  &var_ptr[x] I am using in this sample code, that can be run in the interactive window:
#include <utility.h>
static VARIANT     var_ptr[3];
static int i_type;
static unsigned int  i_val = 12;
static double db_val = 34.56;
static char *str = "ABC";
static int  xi, i, type[3];
static double xd;
static char  *msg;
i_type =  CAVT_INT;      // = 103
CA_VariantSetInt     (&var_ptr[0], i_val);
CA_VariantSetDouble  (&var_ptr[1], db_val);
CA_VariantSetCString (&var_ptr[2], "ABC");
msg = malloc (32); memset (msg, 0, 32);
DebugPrintf ("Received types\n");
for (i = 0; i < 3; i++) {
 type[i] = CA_VariantGetType (&var_ptr[i]);              // first value return is  i_type  = 103   (CAVT_UINT)
 switch (type[i]) {
  case CAVT_INT:
   CA_VariantGetInt (&var_ptr[i], &xi);
   DebugPrintf ("%d: Type %d - Value %d\n", i, type[i], xi);
   break;
  case CAVT_DOUBLE:
   CA_VariantGetDouble (&var_ptr[i], &xd);
   DebugPrintf ("%d: Type %d - Value %f\n", i, type[i], xd);
   break;
  case CAVT_CSTRING:
   CA_VariantGetCString (&var_ptr[i], &msg);
   DebugPrintf ("%d: Type %d - Value %s\n", i, type[i], msg);
   break;
(4,915 Views)
I did very well this issue (VARIANT) , thanks again Smiley Happy
(4,893 Views)
