LabWindows/CVI
Need help terminating an array in LabWindows
Using the finction FindLstn requires an address array. How do I terminate the array. My attached c code shows two methods I tried and the same error resulted.
(3,222 Views)
In your attached source code there was a slight error, in that addr_list[31] = -1; would be outside of the array you created in the above define. The code below works.
Also, placing the FindLstn (0, addr_list, inst_list, 1);
before the loop worked fine for me too.
If you cut and paste the code below into the IM window it will run. (I don't have a GPIB controller board on this PC, but it error'd for that reason. If I made the last element not -1, then it gave me the oerror that you got.
I can only think that you did not assign the array correctly.
Hope this helps,
Chris
#include
static short addr_list[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13,
14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30};
static short ins
t_list[31];
static int j;
addr_list[0] = 0;
for (j = 1; j < 31; j++)
addr_list[j] = j;
addr_list[30] = -1;
(3,222 Views)
