LabWindows/CVI
Need help with string operation
HI,
Although it seems simple....I'm having difficulties to do this....
I'm reading with a bar code the UUT ID as follow:    "ABCDEFG    12"
The number of spaces may vary from 1 to 3.....also the second part may be of 2 or 3 characters.
I'm trying to get the last part into a buffer.  I'm having difficulties due to the fact that the number of spaces is not equal.
Can you help?
(4,002 Views)
Use FindPattern to search for a single space starting from right: this will give you the index of the number after the spaces. Next strcpy (string + index, new_variable) and that's all.
(3,993 Views)
In message <1164287412210-445070@exchange.ni.com>, Rafi2003 <x@no.email>
writes
>HI,
>&nbsp;
>&nbsp;
>I'm reading with a bar code the UUT ID as follow:&nbsp;&nbsp;&nbsp;
>"ABCDEFG&nbsp;&nbsp;&nbsp; 12"
>&nbsp;
>&nbsp;
>I'm trying to get the last part into a buffer.&nbsp; I'm having difficulties due
>&nbsp;
>Can you help?
>&nbsp;
>Thanks
>&nbsp;
I haven't tested this, but it should work.
char barCode[MAX_LEN], barCodeEnd[MAX_LEN];
int i;
strcpy(barCode, "ABCDEFG 12");
for( i = strlen( barCode ) ; 0 < i && isdigit( barCode[i] ) ; i-- );
++i;
if( i < strlen(barCode) && isdigit( barCode[i] ){
strcpy(barCodeEnd, &barCode[i]);
else{
strcpy(barCodeEnd, "No digits");
John Cameron.
Type softly, read gently.
(3,988 Views)
Another possibility, supposing the first part is always and only alphabetic and the second always and only numeric, could be to use
Fmt (string, "%s[t#]%d", string1, number);
the [t#] modifier instructs the Scan function to terminate scanning the source string on the first numeric character. Scan and Fmt functions in the Formatting and I/O are powerful functions and are well documented in the online help.
(3,965 Views)
Or you could just try:
 char Barcode[50] = {"ABCDEFG  \t123"};
 char  String[50];
 int  Number;
 sscanf(Barcode, "%s%d", String, &Number);
This doesn't care how many spaces or tabs are in between the alpha numeric field and the numeric field
Regards
(3,957 Views)
