LabWindows/CVI
Need to copy and format a disk from CVI application
Only success so far is to call DOS command using a script which is not satisfactory. This is for a military application where the user will select the drive letter and disk label from a predetermined list in a CVI panel with the application. (Getting the user to format the disk via the Windows control is not satisfactory.)
Thanks for any help!
(2,846 Views)
If you have the windows SDK, do a search for "File Functions". This will give you a few ideas.
Also, depends if you really want to do a format or just wipe the disk (delete of all files and directorys).
I think a format is a low level driver function (i.e. its calls the driver for the device (HDD / FDD) and that performs the format. Whereas, operations like delete are handled via the OS.
I am checking a few sources of C Libs that I have to see if there is an easier way of doing this.
If you don't have WinSDK, let me know and I shall try and send the relevant info to you,
Regards
Chris
(2,846 Views)
