LabWindows/CVI
Need to know how to get the rise time using NI DMM
Hello everyone. Need your support on how to get the rise time value using NI DMM 4070
(2,440 Views)
kero06,
Hello friend. I found an example program Making Pulse and Transition Measurements with the NI-4070 with the description:
Using standard LabVIEW waveform functions, the example makes transition measurements such as rise time and slew rate as well as pulse measurements such as period, duty cycle, cycle RMS, and upper and lower amplitude levels.
You can download it here, I hope that helps!
http://www.ni.com/example/29420/en/
Additionally here is a long thread about people discussing their approaches to this question:
https://forums.ni.com/t5/Digital-Multimeters-DMMs-and/Rise-Time-Measurement-with-NI-PXI-4070/td-p/11...
Cheers,
Brandon Castro
(2,415 Views)
