LabWindows/CVI
Need to run a shutdown function in a CVI program before Windows XP shuts down and kills my CVI process.
hi all,
I wrote the following procedure and registered it via "SetWindowLong()" to my mainPanel like described above:
LRESULT APIENTRY EditSubclassProc(HWND hwnd,UINT uMsg,WPARAM wParam,LPARAM lParam)
if(uMsg==WM_QUERYENDSESSION || uMsg==WM_ENDSESSION)
//Do cleanup...and:
QuitUserInterface (0);
//Standard-Methode
return CallWindowProc((WNDPROC) pOldEventHandler, wnd, uMsg,wParam, lParam);
two things I do not understand:
1. it runs ok under XP, but the method is not called by the OS under W2K
2. the WM_ENDSESSION is pending. so the OS goes down after closing my application manually. is it possible to change this ?
Any comments or ideas ?
Thanks and best regards
Simon
Message 11 of 12
(1,529 Views)
Hi Simon,
I would suggest researching MSDN for the answers to both of these questions since they more about the Windows SDK. As a starting point, this is the function help for SetWindowLong().
Message 12 of 12
(1,500 Views)
