LabWindows/CVI
Need to use same files and functions for 2 set of hardware (Same hardware)
I have 1 set of files. library.c and library.h.
This files have code to communicate to a device via serial port. This code works fine if I have 1 device attached to my serial port.
library.c file has mutithreading functions and can communicate to only 1 device at a time.
I need to communicate to 2 of these devices simultenously using 2 serial ports. My problem is I have to use same function to communicate with different devices and I don't have mechanism to identify them.
For example:
I have function like send_message. How do I use this function to communicate to 2 different devices? Can I create dll from my code and use 1 set as dll and other set as .c and .h?
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,047 Views)
The usual approach in these situations is to include an extra parameter which identifies the correct hardware. So for example instead of:
    send_message ("A message for the serial port\n");
you could use:
    send_message (port_1, "A message for serial port 1 only\n");
where port_1 is used to select which hardware the function talks to. The CVI RS232 routines need this information anyway, so you just need to use a local variable instead of the port number being fixed.
JR
(3,039 Views)
