LabWindows/CVI
Network-Shared Variable - read string with CVI
I need to read an NSV string with CVI.  I have been digging into accessing and writing NSV with CVI, but they are all scalar value.  What should I do with strings, clusters and arrays?
Message 1 of 8
(7,569 Views)
'm an employee at National Instruments and I wanted to make sure you didn't miss the Network Variable API that is provided with LabWindows/CVI, the National Instruments C development environment. The the Network Variable API will allow you to easily communicate with the LabVIEW program over Shared Variables (https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html). While reading these links, note that a Network Variable and a Shared Variable are the same thing - the different names are unfortunate...
The nice thing about the Network Variable API is that it allows easy interoperability with LabVIEW, it provides a strongly typed communication mechanism, and it provides a callback model for notification when the Network/Shared variable's properties (such as value) change.
You can obtain this API by installing LabWindows/CVI, but it is not necessary to use the LabWindows/CVI environment. The header file is available at C:\Program Files\National Instruments\CVI2010\include\cvinetv.h, and the .lib file located at C:\Program Files\National Instruments\CVI2010\extlib\msvc\cvinetv.lib can be linked in with whatever C development tools you are using.
Thomas N.
Message 2 of 8
(7,540 Views)
Thank you so much.  Been reading other materials.  I will dive into it.
Message 3 of 8
(7,538 Views)
Can you please point me towards example showing how to use read from and write to these NSV on CVI?  Thanks.
Message 4 of 8
(7,519 Views)
Have you already looked at the examples that ship with CVI? You can locate them with the example finder: Help >> Find Examples... menu function, next search for "Network variables": all samples that start with "NV" demonstrate some aspect of this feature.
Message 5 of 8
(7,497 Views)
I am reading NVSubscriber.c.  Can you tell me if I can use the same subscriber (defined by CNVSubscriber) to read different variables, or do I have to use one for each variable.  Thanks.
Message 6 of 8
(7,448 Views)
On my PC, the NV examples are here:   C:\Users\Public\Documents\National Instruments\CVI2013\samples\networkvariable.
However, none of them seem read CNVString value.  please help.
Message 7 of 8
(7,409 Views)
Try:
   char* strValue;
   if (CNVGetScalarDataValue(data, CNVString, &strValue) >= 0)
    fprintf(stdout, "%s\n", strValue);
Message 8 of 8
(6,912 Views)
