LabWindows/CVI
Network Variable Folders
What are the options with regards to creating Network Variable Folders (folders associated with processes)?
                      e.g. \\machine\process\FOLDER\variable
The CVI documentation referrs to allowing for folders but I can't seem to find out the details regarding their creation.
(5,050 Views)
Only some environments create and use Network Variable folders. CVI does not support creating Network Variable folders. But CVI programs can connect to variables in folders created by other environments using the following example syntax:
\\<machine>\<process>\<folder>\<sub-folder>\<variable>.
(5,023 Views)
Thanks for the reply.  Besides LabView, what are my options here?  It doesn't appear the Variable Manager can create (sub)folders.
(5,021 Views)
LabVIEW and Lookout are the two environments I am aware of that support creating network variable folders.
(4,997 Views)
